It is currently Mon Aug 18, 2025 4:49 am
PostPosted: Wed Apr 21, 2010 1:00 pm
Hi all
I saw this a while back and wondered if this is custom made or can you buy them somewhere.
I think it would be very handy
Neil
PostPosted: Wed Apr 21, 2010 1:01 pm
Grizzly has them in 2 sizes
PostPosted: Wed Apr 21, 2010 1:15 pm
Thanks Brock
PostPosted: Wed Apr 21, 2010 1:28 pm
Last Name: Abercrombie
For those who use one of these roller sanders:
How tricky is it to keep the sides flat when using this tool? Doesn't it tend to 'round over' near the bindings?
Just wondering, as I find that a problem even when hand-sanding.
(But I hate hand-sanding sides!)
PostPosted: Wed Apr 21, 2010 1:31 pm
Hey Brock
Went to the Grizzly site and can't seem to find them.
Do you know what they call them?
PostPosted: Wed Apr 21, 2010 1:40 pm
First name: Jeff
Last Name: Struck
State: Controlled Chaos
Country: NJ-USA
Chris Paulick has a video toot on how to make one
I think you can find it on Youtube
Jeff
PostPosted: Wed Apr 21, 2010 1:41 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Hand held pneumatic drum sanders.
[url][http://www.grizzly.com/products/7-1-2-x-2-1-4-Hand-Held-Pneumatic-Drum-Sanders/H2882/url]
http://www.grizzly.com/products/4-x-1-1-8-Hand-Held-Pneumatic-Drum-Sanders/H2881
I've got one. You can mess something up pretty quick with one. I use mine just enough to not sell it, but I do most of my sanding by hand.
PostPosted: Wed Apr 21, 2010 2:03 pm
First name: Jeff
Last Name: Struck
Country: NJ-USA
Here's the link to Chris's toot
viewtopic.php?f=10117&t=25191&p=340060#p340060
PostPosted: Wed Apr 21, 2010 2:12 pm
I've had both sizes for several years. Thought I'd like them for leveling sides but I don't. Sticking the body in the vise and using a wooden block with sticky sandpaper (Or an appropriately sized round caul for the waist) is still the best for me. The place I use them all the time is shaping heels. They are great for that.
Terry
PostPosted: Wed Apr 21, 2010 2:55 pm
First name: kevin
Last Name: waldron
City: Bell Buckle
Zip/Postal Code: 37020
There is a tremendous difference in sanders and operation and technique. check this out http://www.sand-rite.com/touchup.html
We use these a lot but you do pay a premium for the air operated motors. Sandpaper grit and speed control are very important in using these tools even the air pressure in the drum is important. Trying to use a drill want give you the kind of control you'll need nor the feel necessary to use this tool effectively.
Hope this helps
Kevin Waldron
PostPosted: Wed Apr 21, 2010 3:30 pm
First name: Nelson
Last Name: Palen
I use them for the concave areas (waist and cutaway) on the sides but very carefully.
Have good luck with a VSR drill with a VERY light touch to prevent roundover on the edges.
Higher inflation pressure to create a somewhat convex surface across the drum's length is good also but don't overdue the PSI.
The small diameter version works like a dream for fairing in the neck heel to the shaft and even finish sanding the shaft.
Again, a LIGHT TOUCH is adequate. These little jewels will remove maple amazingly well even at low RPM.
The "hardness" of the drum is also controlled by RPM. Centrifugal force due to RPM will tend to make it harder.
Low RPM works great for sanding convex surfaces on the neck as it lets the pneumatic drum conform better.
Nelson
PostPosted: Thu Apr 22, 2010 8:04 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
I have one. I was not quite the tool I thought it would be for the sides but it seems to work well for neck shaping. I bought the one the Chris makes. It works much better for sides. I don't know if he is still selling them, you can contact him and see
Richard
PostPosted: Thu Apr 22, 2010 9:35 am
First name: Bert
City: Gainesville
State: GA
Zip/Postal Code: 30506
I've had a large and small one for twenty years. There is a learning curve when pumping the bladder and controlling the speed. An air drill works best with a speed control. Experience is the best teacher when determining how much pressure to apply to keep from rounding the bindings. I make slow deliberate continuous passes checking the surface with each pass. I always finish with a block to be sure things are level. It works best on neck shafts and the heel.
I bought mine from the same company that Gibson buys theirs. Unfortunately it was so long ago I don't have the name. Gibson called them "rolling pin sanders".
"Try to be the person your dog thinks you are."
http://sites.google.com/site/bertsguitarshop/
PostPosted: Thu Apr 22, 2010 12:31 pm
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
I use these to sand the heel when carving necks. It is a great tool to do the final shaping
John Ressler
